Issue in upgrade GPGA code from 8.6 to 2013
I have a LabVIEW FPGA project whcih is designed in 8.6. When I open it in 2013 I see some of the wires in the target VIs are broken while I can open it with no issue in 8.6
Also when I try to compile the code I get 61055 internal error
Coudl you please let me knwo what shoudl I change to use 8.6 FPGA code in 2013
(2,711 Views)
Fix the broken wires.  I know a lot changed between 8.6 and 2009 in the FPGA world, so I know there was some rework I had to do.  Just don't remember what it was.
(2,707 Views)
I use VHDL code as componenet level IP. For exampel I see some of the FPGA IO Nodes are grayed out so the wires are broken. Has the format of XML files changed?
(2,702 Views)
No, the IP nodes files will need to be updated.  Go in to configure them and regenerate the code.
(2,692 Views)
