Slow execution due to front panel background
Hello, I'm experiencing a issue and I don't know how to solve it, it doesn't make any sense for me. In my project I want to use a background image for the front panel (I choosed the metal brushed from LabVIEW). The problem is that with the background the execution is incredibly slow (I measured about 10% more CPU compsumition just because the background).
Any ideas why? I'm using LV2011
(4,212 Views)
Is that VI a critical one? If not you can set the Priority (VI properties>Execution) as "Background" and execution system as "user interface" and see what happens.
(4,199 Views)
I have not run into the application slowing down due to a FP BG color, but what you could try is  placing on your control/indicators on a scaled "2D picture" control (and import an image similar to what your looking for)  and then monitor your CPU to see if thats what makes the difference Vs. just using the brush tool??
___________________________________________________________________
"I have not failed. I've just found 10000 ways that won't work." - Thomas A. Edison
(4,192 Views)
Well, it does take more effort to draw an image on the background than just a single color.  I wouldn't expect it to cause that much more though.  Are you using a lot of property nodes?  Those would force redraws of the front panel, which is when you would get your hit from having an image.
(4,175 Views)
Hello!
No, I'm not having a lot of property nodes. I tried a workaround and it worked, but no idea why: I created a custom boolean indicator with my background image, I resized it in order to fill the screen and then I moved it to backward. With this, the execution time is the same that without any background. The problem is that in some boolean controls, I can see a "shade box" as it's shown in the picture because they are disabled and grey out. How can I fix it in order to have greyed just the button?
Thank you!
(4,167 Views)
Is your graphics driver reverting to software rendering, I wonder?
(4,157 Views)
What happens of you instead of the boolean place a picture control.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,155 Views)
