Issue on CSV file reading
I tried to read an email data of csv file using read delimited spreadsheet ,but it causing many bugs like it leaves space in between characters, empty array between a row and mismatch data in column of some rows.
Message 1 of 8
(1,738 Views)
Hi kuberr,
And what is your question?
(ReadDelimitedSpreadsheet doesn't cause those "bugs", but most probably the data you feed in.)
Message 2 of 8
(1,734 Views)
There are two possibilities:
  1. Your CSV file is malformed. Where does it come from?
  2. You are reading it wrong. (wrong row delimiter, wrong local decimal delimiter, etc.)
Attach your CSV file and the VI you are using to read it and we will tell you what's wrong.
Message 3 of 8
(1,716 Views)
I guess someone have created "columns" by using space or different amount of tabs to line up the text file.
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 8
(1,700 Views)
Copied/botted from here:
Issue on CSV file reading : r/LabVIEW (reddit.com)
Qestit Systems
Message 5 of 8
(1,691 Views)
CSV files often contain quoted text. The quotes allow for multiline data in one field. Quoted data including a comma can be incorrectly interpreted as a new column.
For an example of parsing a file containing quotes and commas, try the vi in this post:
https://forums.ni.com/t5/LabVIEW/Read-csv-file-with-double-quotes/m-p/1591640/highlight/true#M580390
Message 6 of 8
(1,663 Views)
SLL Toolkit's spreadsheet VIs support quoted strings in CSV files,
Santhosh
Soliton Technologies
Message 7 of 8
(1,651 Views)
Well you should attach the CSV file so we can look at.
If you open the CSV file in question with Excel what does it look like?
It should look the same as the array "Read Delimited Spreadsheet" outputs as long as you are using the correct format specifier.
There can be issues when reading a CSV that has both text and numbers because an array can only be one data type.
So if your CSV contains both strings and numerics you have to
  1. Read the CSV into a string array.
  2. Extract the rows or columns containing the numeric strings you are interested in.
  3. Convert the strings to the proper numeric data type.
  4. Put them in a separate numeric array.
=== Engineer Ambiguously ===
Message 8 of 8
(1,631 Views)
