Issue with VISA device
helph this?
Message 11 of 18
(791 Views)
Yes, do you have some VIs for the operation ?
Thanks.
Learning from other people
Message 12 of 18
(768 Views)
Message 13 of 18
(760 Views)
Hi Sir,
I have downloaded, but still lack of some dependancy Vi, thanks.
For example:
Message 14 of 18
(716 Views)
Where did you put the driver?  It has to go in the instr.lib folder of whatever version of LabVIEW you are using.
Bill
CLD
(Mid-Level minion.)
Message 15 of 18
(699 Views)
Yes, i put it under the folder here, I can see simples for NI PXI, but for the 34461A, still lack of some dependancy.
Thanks.
Message 16 of 18
(689 Views)
There's definitely an issue with the path.  You have an extra folder, "instr" that most drivers aren't going to like.  It should be in this folder: "C:\Program Files (x86)\National Instruments\LabVIEW 2020\instr.lib" (or "C:\Program Files\National Instruments\LabVIEW 2020\instr.lib" if LabVIEW 64bit).
I'm actually surprised the other ones work.
Bill
CLD
(Mid-Level minion.)
Message 17 of 18
(685 Views)
I see, thanks Sir.
Message 18 of 18
(676 Views)
