Issue with Voltmeter VI using LabView and Keithley 6517b
Accepted by topic author cArol32
Sounds as if there might be an issue with the GPIB port either the cable, the PC or the instrument.  First, I would try another cable.  Next, I would try another instrument.  Lastly, I would try another PC.  Change one variable at a time to check the results.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 11 of 12
(225 Views)
I tried running the code and it doesn't work. I made sure that the connection is working and everything.
Message 12 of 12
(219 Views)
