Issues with spreadsheet string to array
Hi, I have a spreadsheet string (tab delimited) and I am trying to convert it into an array of double with 6 digits of precision after the decimal point. However, as shown in the attached example, the function "spreadsheet to array" is not giving me the desired digit of precision (only 2 after decimal point). I have tried almost everything and I am frustrated with this function. CAN SOMEONE PLZ HELP ME ??
(2,822 Views)
I have no LV 8.x installed, so I can't check your Code. But it might be your settings for the indicator. In LV 7.1 it defaults to 6 significant digits, that means the reading is 12345,6789 but (only) your indicator displays 12345,6.
Right click on your indicator (Front Panel) and go to formatting.
Felix
(2,817 Views)
Thank you Felix !  During my troubleshooting, I was right clicking the array and that menu never came up. Thanks to you, now I know that I have to right-click 1 element in the array instead.
(2,812 Views)
