Iterate Over class object controls
I don't think you can use the Oven class, you'll need to use the Oven.ctl, then it should work.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 14
(1,819 Views)
Hmm ... it should've worked ... what's missing?
/Y
Qestit Systems
Message 12 of 14
(1,818 Views)
Accepted by AdamZeroK
There might be some smarter solution, but this works. 🙂
Qestit Systems
Message 13 of 14
(1,815 Views)
Very nice.  Only downside is it won't work without an update if the number of elements of the object change, which is a nice feature of the original code.
As an aside, assuming I don't use a class, combining what you originally posted with the stuff in this other thread allows me to work on an arbitrary cluster without the control[] reference array:
Thanks!
Message 14 of 14
(1,798 Views)
