Join files in sequence
I have around 12 TDMS files for each set of experiments. Each files builds on the previous in terms of wear. So i need to join all these 12 files in proper sequence so that when I need to run a script I dont run it on 12 individual files and then join them later.
Is there a way this can be done?
Message 1 of 13
(4,812 Views)
Hi hmurya,
read those 12 files one after the other and save them all into a 13th file…
Message 2 of 13
(4,760 Views)
I did that. But it still saves as 12 different channels within a file so when I run a script in Diadem it runs on a single channel. I want it all to be one whole file. Unless I am doing something wrong 😕
Message 3 of 13
(4,699 Views)
Hi hmurya,
But it still saves as 12 different channels within a file … Unless I am doing something wrong
That's probably the problem: you are doing something wrong - by not attaching your VI…
You might attach your VI so we could troubleshoot it!
Message 4 of 13
(4,696 Views)
I was given no VI. just a big bunch of tdms files
Message 5 of 13
(4,693 Views)
Hi hmurya,
So I guess you created some kind of VI to actually do "I did this"…
Message 6 of 13
(4,684 Views)
Read all  the TDMS Files and write them in different TDMS File, post the code which you have tried.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 7 of 13
(4,683 Views)
Ok so I am a bit lost. I have attached two tdms files as examples. How would i go about joining them and not having the other smaller valued channels?
Message 8 of 13
(4,661 Views)
Hi hmurya,
the TDMS File monitor shows this:
You need to load just the first signal (first group, first and only signal in group) of each file and save it to a new TDMS file:
Message 9 of 13
(4,653 Views)
how did you load that into LabView?
Message 10 of 13
(4,635 Views)
