Jstification cell/row in multicolum listbox prog?
I want to do  Jstification row in multicolum listbox can i do this?
regard's
eyal.
(2,964 Views)
Click your control so that its selected then goto the Font menu, select Justify then your preference. This seems to affect all cells at once.
There is also a property node under for the ActiveCell to set indiviual Cell Justification.
David
(2,959 Views)
Hi David,
thank's for your replay,but i didn't find the cell justification under ActiveCell  i'm using labview 7.1.
regard's
eyal.
(2,955 Views)
Eyal
Yeah that was for 8.0. I have just had a look at 7.1 and it doesn't appear to be there so you might be out of luck.
What sort of justification are you looking for?
David
Message Edited by David Crawford on 06-05-2006 12:48 PM
(2,951 Views)
