Jumping out of case structures other than by STOP
Here is 7.0
Tim
GHSP
Message 11 of 23
(1,948 Views)
Sorry different post give me a second
Tim
GHSP
Message 12 of 23
(1,949 Views)
Hello aeastet,
Sorry, it needs to be saved in 7.0. I still cannot open 7.1 which is the saved file format!!!!
Nevica
Message 13 of 23
(1,944 Views)
Sorry I am not have much luck switching to 7.0 Maybe someone else can help with that.
Tim
GHSP
Message 14 of 23
(1,943 Views)
Could you save as a screen shot?
Message 15 of 23
(1,939 Views)
Accepted by nevica
You have way too many loops and way too much duplicate code. Here's a quick draft using an event structure and a radio button control.
Message Edited by altenbach on 08-21-2009 09:48 AM
Message 16 of 23
(1,920 Views)
Thanks Altenbach,
Your programming style is new to me so I will have to unpick what you have done.
Nevica
Message 17 of 23
(1,885 Views)
In the vi attached I am trying to make 'Instrument I/O Assistant 2' map to case structure 1, 'Instrument I/O Assistant 3' map to case structure 2 and 'Instrument I/O Assistant 4' map to case structure 3 within the inner case structure.
How do I do this in Labview 7.0
Message Edited by nevica on 08-26-2009 11:00 AM
Message 18 of 23
(1,855 Views)
You need to add a second shift register. Then you hook it up like the picture below.
Tim
GHSP
Message 19 of 23
(1,847 Views)
Thanks Aestat,
But how do I set 'Instrument I/O Assistant2' to 1 and so on within the case structure itself. At the moment 'Instrument I/O Assistant 2' is set to 0 which is not what I want. they all need to be mapped up by one to agree with the strings.
I have tried re-arranging by right clicking then 'rearrange cases' but without luck. Does a case structure always have to have a zero case. If this is so then I will have to subtract one from the input to the case structure.
Nevica
Message Edited by nevica on 08-27-2009 03:09 AM
Message 20 of 23
(1,817 Views)
