07-25-2005 04:10 PM
07-25-2005 07:47 PM
cw3dgraph just shows up at the same time as the new version of LV.
I have not heard of any changes or fixes.
I have seen the defaults for cw3dgraphs get lost in the upgrade from 6.1 to LV 7.1.
I would first try going to the 6.1 version of the graph in edit mode and pop-up >>>CWGraph#D >>> export style
save the file
Then in the upgraded version do the import style.
If that does not fix it post your code and tell us what is wrong. There are things you can do to the 3dgraph that work just fine as you have saved all the correct defaults. If we know what is supposed to happen we may be able to direct to what got lost in the upgrade.
Ben
