Just up graded to Labivew 7.1 from 6.1 3-d graphs dont work right where can I get lattest version of cw3dgraph
Recently up graded to Labivew 7.1 from 6.1.  3-d graphs dont work right.
VI's using the Activex 3-D graphs developed in 6.1 worked fine.  Since up grading to 7.1 the graphs work after a fashion but many features don't. Anyone else have a similar problem?  Don't have the technical support from Labview, but then I figured the software should run as advertised. Where can I get lattest version of cw3dgraph?
(2,415 Views)
cw3dgraph just shows up at the same time as the new version of LV.
I have not heard of any changes or fixes.
I have seen the defaults for cw3dgraphs get lost in the upgrade from 6.1 to LV 7.1.
I would first try going to the 6.1 version of the graph in edit mode and pop-up >>>CWGraph#D >>> export style
save the file
Then in the upgraded version do the import style.
If that does not fix it post your code and tell us what is wrong. There are things you can do to the 3dgraph that work just fine as you have saved all the correct defaults. If we know what is supposed to happen we may be able to direct to what got lost in the upgrade.
Ben
(2,410 Views)
