Keep VI running when pop-up window is showing
I place a button in my program that when I click it and the text meesage will pop up.
But when the window pops up, the main VI will freeze until I click the OK button of the pop-up window.
(in the uploaded example, when OK button is clicked, number will stop adding untill I click the OK button of pop-up window.)
Is there any way to keep the vi running when the pop-up window is showing?
thanks a lot!
Message 1 of 8
(5,485 Views)
Button dialog will freeze the calling VI so its always better to develope a custom sub VI instead of using Button dialog
Message 2 of 8
(5,427 Views)
Accepted by IanYuan
Hope this link will answer your question. You need to develope your own pop up VI and launch it dynamically from your Main VI.
Message 3 of 8
(5,413 Views)
why to call the sub vi dynamically, any reason for calling dynamically instead of just calling the POP UP sub VI same as dialog button used.
Message 4 of 8
(5,404 Views)
OP was asking that "Is there any way to keep the vi running when the pop-up window is showing?". So it is required to call the subvi dynamically.
Message 5 of 8
(5,392 Views)
How about running in parrallel POP UP in one Loop and Incrementing Values in another Loop.
Message 6 of 8
(5,373 Views)
Running in parallel loops also a good optionSmiley Happy. Based on the requirement user can choose.
Message 7 of 8
(5,361 Views)
Many thaks for Nanthakumar's link and Palanivel's answering!
I'll try to apply it in my program.
Message 8 of 8
(5,301 Views)
