Keep VI running when pop-up window is showing
I place a button in my program that when I click it and the text meesage will pop up.
But when the window pops up, the main VI will freeze until I click the OK button of the pop-up window.
(in the uploaded example, when OK button is clicked, number will stop adding untill I click the OK button of pop-up window.)
Is there any way to keep the vi running when the pop-up window is showing?
thanks a lot!
Message 1 of 8
(5,387 Views)
Button dialog will freeze the calling VI so its always better to develope a custom sub VI instead of using Button dialog
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 2 of 8
(5,329 Views)
Accepted by topic author IanYuan
Hope this link will answer your question. You need to develope your own pop up VI and launch it dynamically from your Main VI.
Message 3 of 8
(5,315 Views)
why to call the sub vi dynamically, any reason for calling dynamically instead of just calling the POP UP sub VI same as dialog button used.
Message 4 of 8
(5,306 Views)
OP was asking that "Is there any way to keep the vi running when the pop-up window is showing?". So it is required to call the subvi dynamically.
Message 5 of 8
(5,294 Views)
How about running in parrallel POP UP in one Loop and Incrementing Values in another Loop.
Message 6 of 8
(5,275 Views)
Running in parallel loops also a good optionSmiley Happy. Based on the requirement user can choose.
Message 7 of 8
(5,263 Views)
Many thaks for Nanthakumar's link and Palanivel's answering!
I'll try to apply it in my program.
Message 8 of 8
(5,203 Views)
