Keep getting Error 6 from TDMS Deframent VI (LV 2009)
After closing my TDMS file I run the TDMS Defragment VI and keep getting Error 6 (generic file error). What could be causing this?
George
Message 1 of 9
(4,081 Views)
One of the possible reasons is that the file cannot be opened, according to the error code. What type of the windows account? Do you have the permission to create files in the windows temporary directory?
Message 2 of 9
(4,069 Views)
The file had just been created and written to a few steps earlier in the program so I can't see how there'd be any kind of permissions problem. Does it take a while for a file to close before it can be defragmented? I've problems like this before and putting a short delay in helped. But I have a 3 second delay in there now and it didn't help.
Message 3 of 9
(4,062 Views)
Are you using LV 2009 and produced this problem? And how big of the file? Is that larger than 64MB?
Message 4 of 9
(4,033 Views)
Yes, 2009 (it was in my title) and the file is < 200k.
Message 5 of 9
(4,021 Views)
We had a known issue of defragment TDMS files which are larger than 64MB in LabVIEW 2009, but it doesn't apply to your problem. Is that convenient for you to post your VI here? Maybe we can take a deeper look in your code.
Message 6 of 9
(4,016 Views)
Unfortunately it's very big and you'd need some special instruments as well.
I attached a picture of the bit of code used for the defrag.
George
Message 7 of 9
(4,012 Views)
There's a problem of fopen function which is used in TDMS Deframent, http://connect.microsoft.com/VisualStudio/feedback/details/498145/fopen-sometimes-fails-after-callin...
It seems the problem not only happens on Windows 7, but also happens on other Windows platform.
A possible workaround is to try Defragment for multiple times even the error happens.
Message 8 of 9
(3,994 Views)
Thanks very much. It sure seemed like a bug to me.
George
Message 9 of 9
(3,984 Views)
