proggramming Encoder to daq assistance
  greetings.
can i know how to program or is there any example of .vi where i could get on controlling a dc motor position angle? plus with daq assistance..I have tried but could not get the idea
im using labview 8.6 with usb6009.
the hardware have been connected for me through the usb6009.
the application of the hardware is to control the amount of sunlight through windows blind.
im also using a maxon twin shaft dc motor with 5bit encoder.
another 1 is, can my .vi be used as a close loop system that can control the angle of my dc motor when the sensor is adjusted?. if yes, then how can i figure the program with daq assistance?
undergraduate local student inspired to use LabView for final year project
nubies here need guidance.
(3,000 Views)
Yes, you can make a close loop to control you motor.
Please check up the below link on examples of motor control using LabVEW.
(2,961 Views)
thank you for replying..
i could not see any link below..
could you please attach any related link/url?
(2,937 Views)
