Keeping track of CSV formatting
Ok,
I am having issue with keeping the formatting of CSV files. Traditionally, I have uses TXT file formats to keep track of everything from data to calibration curves. I use tab delimiter in over 10 or so years of doing this I have never had any issues.
Fast forward to now, I was in a bind and out sourced some work to a contractor. Even though I gave them a specific style guide, they did a lot of things their own way i.e. CSV vs TXT. Since the project was much more than just LabVIEW code I couldn't really reject the work.
The problem is that customers are opening the CSV files in numerous programs (Notepad, Wordpad, Excel, OpenOffice, etc.). I am finding that some programs insert quotes around row data. By example a specfic row should look like this:
pH Slope,10
pH Intercept,-15
Instead it look like this:
"pH Slope,10"
"pH Intercept,-15"
When I search the file for pH Slope I don't find it.
In addition to that, sometimes additional rows are added all together and look like this:
"pH Slope,10"
"pH Intercept,-15"
I will use a Search and Replace subVI to remove all the " and remove them. But what is the best way to elimate this type of things from happening all together?
Doug Ferguson
(2,876 Views)
The best way is to reject the work and tell them to give you what they were contracted to give you. Excel will take liberties with a file that has a CSV extension. Writing a VI to remove the quotes is kludgy but it will work as long as you never expect quotes to be contained in valid data.
LabVIEW 2012
(2,861 Views)
Based on what you are describing, I expect your customers are opening the files in a spreadsheet program, but are not using a comma as a delimiter.  So, if they re-save the file, the spreadhseet is putting quotes around the text blocks.
At this point, as you said, you will probably need to remove the quotes and blank lines (that I have no insight on).
If your customer are modifying/saving these files, either tell them to import them correctly, or not to use anything but a text editor.
(2,857 Views)
Also, if the customer is willing to only open the files in Excel, you might look into TDMS. I realize that the project is done and I only suggest this for future projects. TDMS is greatly overlooked by many people including myself.
LabVIEW 2012
(2,821 Views)
