Keithley 2100 temperature
Hi, I Have a keithley 2100 6 1/2 Digit Multimeter and I need to mesure temperature with it but I don't know how to do that, I could only found how to mesure DCV ACV resistence etc but I didn't found a way to put my PT-100 alpha beta and delta configurations for my pt-100 and to read temperatures.
A little help please?
thanks
Message 1 of 8
(5,964 Views)
What have you tried so far??
Do you have the LabVIEW drivers for this instrument, if not, then find it here.
You might also want to share your code..!!
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 2 of 8
(5,961 Views)
I have a code downloaded from keithley website only I'll send you.
I'm using the code in: Keithley 2100 Series/Exemples/Keithley 2100 Series Read Single
In that code in function diode I changed to TEMP and the multimeter has changed correctly now I need to configure it
Message 3 of 8
(5,956 Views)
There is a configuration VI: '..\Keithley 2100 Series - lv2012\Public\Configure\Configure Temperature.vi' which allows to set Alpha, Beta & Delta constants.
Configure temp - Keithley
Make sure after downloading the drivers you keep it in 'C:\Program Files (x86)\National Instruments\LabVIEW 2012\instr.lib' folder as shown below...
Keep instruments driver here
Message 4 of 8
(5,945 Views)
Thanks, that helped a LOT!!! THANKS!!!
Onle last question what should I call in my VI in order to get the temperature read by the multimeter? that vi you said configures the temperature but where can I READ the temperature and use it? THANKS!!
Message 5 of 8
(5,940 Views)
Accepted by Top24
Hi, for most of the drivers, there has to be a VI Tree...!!
For Keithley 2100: C:\Program Files (x86)\National Instruments\LabVIEW 2012\instr.lib\Keithley 2100 Series\Public\VI Tree.vi
This VI lists all exposed (public) functions of the library (well I can't see 'Configure Temperature.vi' under configuration)...
You should be using one of the Data functions.
Read Functions
Message 6 of 8
(5,932 Views)
Thanks a lot!
You are the best.
Thanks again problem solved
Message 7 of 8
(5,926 Views)
One last question, I can't call these VI's in MY project 😕 how can I do that I was tryingo to initialize then to configure temperature then aquire single data but it is not working 😕
Message 8 of 8
(5,914 Views)
