Keithley 2450 4 wire resistance measurement
I'm a student who study at material design lab in SKKU, Korea.
I'm new in labview program.. I want your advice.
I want to measure 4 wire resistance measurement with bias current input with Keithley 2450.
I downloaded driver.
This is the whole VI,
I used sub VI a lot because I need to use in another code.
I notice I have to use "Enable Remote Sensing"  - after that "Enable Output" from searching.
But when I run the code and look at the front panel of Keithley, it shows two wire mode, measuring current, input voltage..
What component should I adjust?
Thanks.
Message 1 of 8
(5,601 Views)
Not sure if this will help but here is the pertinent part pulled from one of our routines.  I don't see anything obvious for order of operation that would cause yours to not work, but I don't have direct access to the hardware currently to test it out.
Message 2 of 8
(5,568 Views)
thanks for reply.
I build this VI again, but it gives
2 wire mode, resistance measurement, input voltage.
I have no idea what sub VI can set 4 wire mode...
Did I miss something?
Message 3 of 8
(5,545 Views)
I found that if I do in this sequence, it can measure
input current / 4 wire voltage measurement mode / voltage output
when I use Keithley program to measure sheet resistance, it measure resistance using 4 wire voltage measurement mode.
So I guess using 4 wire voltage measurement mode is right, but I don't know how to make output as resistance ( ohm unit )..
Do you have any solution for this..?
thanks
Message 4 of 8
(5,541 Views)
Check this old thread. It is also regarding 4 wire resistance measurement using keithley 2440. It might help you.
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/keithley-2440-source-meter-4-wire-measuremen...
CLD Using LabVIEW since 2013
Message 5 of 8
(5,538 Views)
Hello
I want to measure 4 wire resistance measurements with bias current input with Keithley 2450.
I downloaded a driver that gives an error.
I could not find the relevant driver. can you help me? send me the download link for the driver 4 wire resistance measurement.
Message 6 of 8
(4,727 Views)
 i have not run 4 mode LabVIEW program in 2016 lab view. plz send 4 mode labview code for 2016 version.
Message 7 of 8
(4,427 Views)
Hi Bisht,
Did you already checked the IDNet?
Message 8 of 8
(4,421 Views)
