Keithley 2600 and labview
hello mates,
i need your help urgantly
i need to write a program with labview to use channel A output voltage as an input for channel B
your help is really appreciated.
(3,043 Views)
To communicate with your Keithley 2600 you have the instrument driver here and on the Keithley website you can download here all the necessary software for LabVIEW. Also I attached the zip file which contains all the VIs with some good examples that will help you to implement your program.
I hope this helps.
Steve M.
(3,020 Views)
