Using keyfocus and enter key, if key pressed more than once, value is stored, how do I clear this value? We are using key focus on a sub-vi that is running, the enter key is pressed and the sub closes and the main regains focus. However, if the enter key is accidentaly pressed twice, the second value is stored and the next time a key focus for enter is present, it is executed, is there a way to clear this buffer?
