Key focus and enter key storing and erasing values?
Using keyfocus and enter key, if key pressed more than once, value is stored, how do I clear this value? We are using key focus on a sub-vi that is running, the enter key is pressed and the sub closes and the main regains focus. However, if the enter key is accidentaly pressed twice, the second value is stored and the next time a key focus for enter is present, it is executed, is there a way to clear this buffer?
(2,570 Views)
It may be profitable for you to post your code for us to look at.
It sounds like you have a boolean that is associated with the return key that is getting pushed an extra time while the sub-VIis exiting. If this is the case, you may have to set the boolean explicitly when the sub-VI starts.
There are other possibilies but I will not go into those with just a guess.
Ben
(2,570 Views)
