Keyence DL-EN1 TCP
How are you good night! These days I am trying to communicate a Keyence DL-EN1, which is connected to two GT2 amplifiers, Using the commands for Measurement Reading "M0" and "SR" the adapter returns me a command write Error message " ER, M0 or SR, 255 "Checking with another USB sensor via VIsa No Problem, You send the command and it gives you the measurement reading. Does anyone know what the problem is? I have a fixed IP and Port already determined on DL-EN1
(5,710 Views)
We are experiencing similar issues to what you were seeing back in March. Did you ever find an solution to this problem?
(5,203 Views)
Hi, how are you? if the problem was because the command was sending it without end and return characters
I hope it will help you with something
(5,181 Views)
TCP open connection
        Set IP Address as you know.
        Remort Port defualt is 64000
           # IP and pot can set via Keyence utility software DL-EN1 IP configurator.
TCP write
       CMD must end with \r\n(x0D0A) ex SR,01,307\r\n
TCP Read
       set mode as CRLF
       Set byte to read as 100.(it will stop read if find CRLF)
hop can help.
(4,059 Views)
TCP open connection
           # IP and pot caan set via Keyence utility software DL-EN1 IP configurator.
TCP write
TCP Read
       set mode as CRLF
       Set byte to read as 100 (it will stop read id find CRLF.
holp can help
(4,056 Views)
Hello All,
May be this might help to understand better with Block diagram.
Cheers
(2,421 Views)
