Kill remotely LabVIEW process on Windows 7 and 8.
What is the best way to kill "remotely" a LabVIEW process.  Example: Computer A wants to kill a LabVIEW executable on Computer B.  Both computers can run Windows 7 or 8.  The two computers are on  my LAN and I have the administrative priviledge on them.
I have tried with "pstools" but I can't get it to work.
Michel
Message 1 of 9
(4,300 Views)
If you can change the LabVIEW program, than add a TCP listener in it.  On Computer B, send a message, e.g. "Exit", to terminate the LabVIEW program nicely.
If you can't change the program, then try Windows Remote desktop.
George Zou
Message 2 of 9
(4,281 Views)
My current need is to kill the LabVIEW application that runs on Computer B programmatically from a LabVIEW application that runs on computer A.
Message 3 of 9
(4,274 Views)
Accepted by Michel_Gauvin
So can you change LabVIEW program on both computers?
If not, can you create a new program just to kill the named process?
George Zou
Message 4 of 9
(4,258 Views)
Hello zou,
Yes I can modify both application and I can create a new one.
I'm going with the creation of a new one.  The kill was in the case where the application hang (for any reasons) after a few month.  A backup application will take over but I want the backup application to "try" to kill the previous active one.
Michel
Message 5 of 9
(4,247 Views)
Have you played the Windows service before?
LabVIEW can create a Windows service.
Use a service to monitor an application to make sure it works.
If not, kill it and launch another instance of it.
Hopefullly, a LabVIEW service is more reliable than a LabVIEW application.
George Zou
Message 6 of 9
(4,243 Views)
Hello Zou,
The windows service is a good idea which I want to pursue.  I never played with windows service in the past and I've made search on ni.com to find how to make one to run under Windows 7 or 8 but without any success.  Do you have a link that you can share that explains how to do it?
Michel
Message 7 of 9
(4,182 Views)
Message 8 of 9
(4,157 Views)
Message 9 of 9
(4,157 Views)
