Kinesis Thorlabs Cage Rotator
Hello everyone!
Does anyone have an expample of any LabVIEW program for the cage rotator of Thorlabs, namely K10CR2/M.
They have a guide for the Kinesis software, but I am not able even to success with basic stuff.
Thank you
(909 Views)
What specific problems do you have with "basic stuff"?
Also, have you seen this thread?
https://forums.ni.com/t5/Motion-Control-and-Motor-Drives/Control-of-Thorlabs-K10CR1-cage-rotor-devic...
It's for the CR1, not the CR2, but they did post a block diagram.  Their problem was a bit more complex but the code example they posted (as a png, unfortunately) indicates they got it working.  It might be a starting point that helps you.
(888 Views)
Ok, to be more specific, I am struggling even with the connection to the device. I am trying to set up an even simpler program, which should give the position of the motor. When I run the program, it first says, "No suitable device is found", and then an error from LabVIEW. I followed the instructions of the Kinesis LabView Guide, and I can't find the problem.
The installed Kinesis program works fine, though.
(849 Views)
Accepted by topic author This_Is_Mecco
Ok this one seemed to have the same issues you are having. Look at this tread:
https://forums.ni.com/t5/LabVIEW/Using-Labview-with-kinesis-to-control-Thorlabs-BPC303/td-p/3763105
Tim
GHSP
(838 Views)
Thank you for sharing this thread with me.
Now I have the program, based on the suggestions, and it works well (see screen).
Though I didn't type in the serial number in a way 7XXXXXX, it didn't work for me. Just the number works fine.
Also, if I abort the execution, then the connection to the rotators is lost.
I also wonder if I can avoid using the Cage Rotator Control to do not see the interface of the Kinesis. Is it even possible? I think the LabVIEW process slowly when using this, no?
(813 Views)
If all you want to do is not see the front panel .Net control, you could simply move it out of the visible portion of the front panel.  An alternate would be to change its "visible" property to false.  There is a property node that will do that from the block diagram (although I could not find one in the "Properties" list on the front panel).  You can also use a block diagram constructor, but this can be a bit of work, so unless there is a compelling reason to take this route, one of the other options may be better.
(805 Views)
