Knob Control with hex values for the scale
Yes, I can also confirm this to be be a bug in 8.2.1.
Another curiosity:
If you go to the "advanced editing mode", the %02x format (for example) is valid, but if you e.g. delete the x and then put it back, it claims the format is invalid . same for octal and binary formats.
Clearly a bug!
Message Edited by altenbach on 07-09-2007 12:05 PM
Message 11 of 14
(913 Views)
I am using 8.2 and the properties menu does not let me set a hex format for the knob scale
Kaspar
Message 12 of 14
(890 Views)
This was reported to R&D (# 4B9C05LJ) for further investigation.  The suggestion of creating a property node from the control and setting the scale->format property manually should be a good workaround for now.
Thanks for the feedback!
Craig D
Message 13 of 14
(861 Views)
Craig D
CAR ID is actually 4B9D5HLJ.
Roy
Message 14 of 14
(818 Views)
