Kunbus Profibus Package v. 2.0.2 does not install LabVIEW VIs
I have an old comsoft PCI Profibus card that I need to develop new software to control. I had the older comsoft drivers and VIs, but I wanted to make sure I used the latest driver package for the new software. I found the Kunbus (new owner) profibus software and driver package, v. 2.0.2, on NIs website, downloaded, and installed it. I fired up Labview 2019, 32-bit and the VIs were not in the VI pallet. Is there a part of the package that I missed during download or installation?
(2,332 Views)
I'd try the steps in the article below:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019KmbSAE&l=en-US
Also, just to confirm, you installed LabVIEW first and then the driver correct?
I'd also check to make sure your version of LabVIEW is compatible with that driver
(2,246 Views)
Misbahd,
Labview 2019 was installed on my PC before I started this project. I checked the Kunbus download and it doesn't seem to contain any VIs. I checked the folders created by the Kunbus installation and did not see any VIs there. I checked my vi.lib folder for all of my Labview versions and did not find any new VIs there.
I found the older Comsoft VIs from 5 years ago, but I am not sure if they are compatible with Windows 10 and Labview 2019.
(2,222 Views)
