LABVIE +LINX + ARDUINO SERIAL COMMUNICATION
Hi Everyone.
I want to write serial data to  "2 Channel PWM Pulse FrequencyWave Signal Generator Module" which has the serial port.  I have connected to Arduino Mega2560.  I have used Linx but not writing the value attached VI Code not sure what is cause. or am i using the right method. My question is can i write labview program to send data to third party device with serial channels available on mega2560 ? If yes i am using linx will that work.
Please someone suggest me..
(5,687 Views)
Accepted by SantoshK
I am also trying to use Serial communication (USB) with arduino through LabView Communications. I am able to make it work with standard LabView, but I have yet to find a method for LabView Communications
(5,657 Views)
I have done its working .. check below youtube link.. Sent data from Master Mega 2560 to Slave 2560 using labview
https://youtu.be/BhsX3Ciwsw4
Santosh
(5,604 Views)
