LABVIEW APPLICATION HANGS DUE TO INSUFICIENT MEMORY
I AM USING LABVIEW 7.1. I BUILD ONE APPLICATION. IN THAT APPLICATION I USED MSCOMM ACTIVEX FOR SERIAL COMMUNICATION TO MY PLC. ALSO I USED TOOLBAR , STATUS BAR ACTIVEX IN MY APPLICATION. IT WORKS OK. BUT AFTER SOME TIME SOFTWARE GET HANGS DUE TO INSUFFICIENT MEMORY. I FOUND THAT AFTER 3SECOND THAT EXE SIZE IN MEMORY GET INCREASED BY 4K. WHY DON'T KNOW. PLEASE TELL WHY MEMORY SIZED INCREASED.
(2,688 Views)
How can we say why, without seeing your code ?
-Check if you open references and not closing them.
-Use "Performance and Memory" to see in which vi, the memory is increased
(2,685 Views)
