LABVIEW FPGA - log High speed encoder readings
I'm new to LabView FPGA. I have an encoder with 1000 ppr. I want to log each pulse from the encoder against a time stamp for 20 seconds at 4000 rpm. So that means I will have to log 66 666 pulses per second. I need to log all these pulses against a time stamp.
I don't need to access data in real time. Since I need to acquire data only for 20 seconds, it is more than enough if I can access them after data acquisition.
I am using a cRIO - 9024 with the high-speed digital card NI 9401.
I need this to finish my MPhil thesis. And I'm in a bit of a hurry since my scholarship is only good for next 3 months.
Thank you. I really appreciate if anyone can help me. I'm really screwed if I cannot get this right.
(3,302 Views)
Accepted by waruna1993
Hi waruna,
With each rising (or falling) edge of your pulse input you store the current timestamp of your FPGA into a FIFO. Read the FIFO on the RT host and store the timestamps into a file (or stream them to your PC host).
"Timestamps" on the FPGA can be just a counter of the DI loop iterations - your DI loop should iterate with a know timing/rate!
You should learn about:
- using LabVIEW FPGA in general
- creating loops with known timing (iteration rate) on the FPGA
- creating a simple counter in the loop
- sending data from FPGA to RT using a FIFO
(3,248 Views)
