LABVIEW FPGA - log High speed encoder readings
I'm new to LabView FPGA. I have an encoder with 1000 ppr. I want to log each pulse from the encoder against a time stamp for 20 seconds at 4000 rpm. So that means I will have to log 66 666 pulses per second. I need to log all these pulses against a time stamp.
I don't need to access data in real time. Since I need to acquire data only for 20 seconds, it is more than enough if I can access them after data acquisition.
I am using a cRIO - 9024 with the high-speed digital card NI 9401.
I need this to finish my MPhil thesis. And I'm in a bit of a hurry since my scholarship is only good for next 3 months.
Thank you. I really appreciate if anyone can help me. I'm really screwed if I cannot get this right.
(3,244 Views)
Accepted by topic author waruna1993
Hi waruna,
With each rising (or falling) edge of your pulse input you store the current timestamp of your FPGA into a FIFO. Read the FIFO on the RT host and store the timestamps into a file (or stream them to your PC host).
"Timestamps" on the FPGA can be just a counter of the DI loop iterations - your DI loop should iterate with a know timing/rate!
You should learn about:
- using LabVIEW FPGA in general
- creating loops with known timing (iteration rate) on the FPGA
- creating a simple counter in the loop
- sending data from FPGA to RT using a FIFO
(3,190 Views)
