LABVIEW FPGA running Sub Vi without Host
I have a content for the SBRIO board - RT and FPGA applications. The SBRIO runs as standalone control block.
The RT application is divided into number of VI-s and runs OK.
Now I want to split the FPGA application into number of VI-s - one main and number of SuVI-s.
Unfortunately, here I am encountering problem with Running state.
I am starting the main VI but the SubVI-s enter "waiting for run" state and I cannot force them to run.
Where is my problem?
Message 1 of 15
(3,298 Views)
remark - each SubVi runs as endless loop
Message 2 of 15
(3,270 Views)
Hi Rubi,
How do you know your FPGA subVIs are in "waiting for run" state?
When you run the FPGA VI on system startup then the whole FPGA VI including its subVIs should run…
We don't know your code so an error analysis based on your description is rather limited…
Message 3 of 15
(3,269 Views)
Hi Rubi,
Now it sounds like a simple "THINK DATAFLOW!" problem!
One subVI blocks other subVIs from executing!?
Message 4 of 15
(3,266 Views)
The white arrow in SubVI changes to "wait for run" after the main VI is started (pressed the white arrow).
The SubVI-s are called in such way:
If am copying the content of sub-VI-s back to the main - all loops inside them are running OK.
Message 5 of 15
(3,259 Views)
Hi Rubi,
I still don't know how you could observe a VI running on a FPGA: the code is compiled into FPGA fabric, so either the whole code runs or nothing…
This doesn't look like a DATAFLOW problem, but we still don't know what's inside of the subVIs…
Message 6 of 15
(3,248 Views)
Inside most of the sub-VI-s are endless loops:
I also supposed that all VI-s are incorporated into the fabric and cannot be stopped.
But in such case it is not clear white arrow wit tooltip "waiting for run"
Message 7 of 15
(3,244 Views)
As someone who has FPGA code with lots of individual VIs with endless loops, something about your description does not make sense.
How are you "running" the code on your FPGA.
Have you connected the "Open FPGA Reference" to a bitfile, VI , build-spec?
Message 8 of 15
(3,229 Views)
I am working on project that was started by someone else.
The main FPGA VI added to the RT project via adding the FPGA Reference (*.ctl) to the source files list.
The RT VI-s exchange data with the FPGA using the FPGA References pointing to different VI-s on the FPGA side.
The original design includes single VI that runs well.
Now I am trying to re-organize it by splitting the single huge VI into main and number of SubVI-s.
Message 9 of 15
(3,202 Views)
"different VIs on the FPGA side" means different bitfiles.
Can it be that each VI is trying to run a different bitfile? That would cause (of course) resource contention issues as only one FPGA bitfile can be deployed at a time.
Message 10 of 15
(3,190 Views)
