LABVIEW FPGA running Sub Vi without Host
I don't think.
The FPGA build includes single bit-file where sub-VI-s are added through the Build Specification:
and at the runtime the SubVi-s are called directly:
Message 11 of 15
(875 Views)
"The FPGA build includes single bit-file where sub-VI-s are added through the Build Specification:"
Please explain what you mean by this, your descriptions are very vague and cryptic. It's almost like you're obfuscating on purpose.
Message 12 of 15
(870 Views)
Accepted by topic author RubiMesh
It looks that I found the solution.
To add the subVI to the bitfile it shall be defined as pre-allocated clone in execution properties:
Other parameters shall be set too to enable active front panel for this subVI
Message 13 of 15
(840 Views)
-pic-
This makes no sense to me at all.
This all sounds like it's all on the RT system, not the FPGA at all.
Message 14 of 15
(832 Views)
The timing is very tight (the UART runs at ~400K and responses sent in 10-20 uSec) cannot be achieved on the RT
Message 15 of 15
(824 Views)
