LABVIEW
I have some dymanic data ,,,i need to check all those data and as per requirement i will take only one data at a time from those dymanic data and use that data in other purpose as a input  ,,how can I implement this in LabVIEW??
(3,387 Views)
Tell us more about your dynamic data. Is it an array?
The simplest thing I can imagine is use a for loop and wire up your array using the autoindexing tunnel. The for loop will step through the array one element at a time and you can write code that operates on each element, such as acting as the input for some other function like you describe.
CLA - Kudos is how we show our appreciation for comments that helped us!
(3,378 Views)
Actually I have a analog signal,,which I get from Daq assistant,,,i want to use those input ,,,i hope that is a dynamic data ,,,i want to check all those data one by one and my program will check those data with a specific vale which is constant ,,and as per requirement the program will increase or decrease of that value one by one,,this is my object ,,,so I want to know that what will be the code for this program??
(3,372 Views)
Accepted by tendoraj22
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(3,339 Views)
