LED Persistence
I would like my program to do turn an LED on when the INPUT > X. If the input then drops, the LED will stay on for 10 seconds before turning off.
I have figured how to turn an LED on when INPUT has been > X for 10 seconds, but not what I need.
(3,137 Views)
Hi alarmharm,
I would recommend using a state machine for your application.  More information on state machines can be found here: https://www.ni.com/docs/en-US/bundle/ni-vision-labview-api-ref/page/imaqvision/imaq_arraytoimage.htm...
You can have a state that waits for INPUT>X to transition into a state that turns the light on and waits for INPUT<X.  This state would transition into a state that waits for 10 seconds and then turns the LED off which then goes back to the original state that waits for INPUT>X.
(3,086 Views)
Perhaps you can use something like this as a starting point.
(3,056 Views)
