odd cluster appearance
I created a cluster constant containing 6 booleans with descriptive labels.  When I made it a typedef the appearance changed to this:
Now I have obese booleans!  Anyone else encounter this?
The width of the booleans seems to be related to the length of text in the label.
I can still click on the booleans and change their values.  I can change to the icon view and see the normal icon, but when I change back, I get the fat booleans.
I had to delete the cluster and place a new instance of the type def to get back to the normal appearance.
(3,635 Views)
What version of LabVIEW are you using?  I seem to remember a corrective action report about this issue awhile back, but I believe it has been fixed.  Let me know and I will try to track it down.
(3,604 Views)
Sorry, left out the important details.  This happened in LabVIEW 2012 (Version 10.0f1 32-bit) running under Windows 7 Professional, 64-bit.
(3,599 Views)
Thank you.  We found this internally a few months back, just after the release of LabVIEW 2012.  It is CAR 361839 if you want to track it.
(3,587 Views)
With scripting, you can make your boolean constants any size (and any color).
(3,548 Views)
