LED change blinking
Halloooo ,im a newbie in labview , i got a small problem
how to i make a loop for 2 LED light so that they can blink ?
for example , a control and two LED lights (a and b)
when the control turns on , a lights turn on while b lights is off , and then b lights turns on , a lights is off
they loop until the control turns off , then both lights are off , any senior or pro can teach me 😞 ?
(3,525 Views)
Show us what you did so far and we will point you in the right direction. 🙂
(3,514 Views)
have you tried using a not wired to a shift register
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,507 Views)
Here is an example.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,486 Views)
@Gak wrote:
Here is an example.
One problem here is the overuse of local variables. None are needed here!!!
If the same indicator needs to be written in both cases, the solution is to place the indicator after the case structure. Here's a quick rewrite that shows a better solution. (the other case is empty and the tunnels are set to use default if unwired).
(LOL!, in case this is a class problem or homework, be prepared to fully explain every aspect of the code, so study it well! :))
(3,468 Views)
