LED on for 5 seconds and off 3 seconds
Hi
      I want to turn on the LED for seconds and off for 3 seconds.And repeat this process till I press the stop button.How can I go about it?
                   V I P U L L
        < <R E L A X I N G > >
W E L L . . .QUITE THE SAME WAY
Regards
RobinHood
(5,196 Views)
Thanks to Altenbach, for this example in other thread. I will try to find out where it is exactly and post back.
Message Edited by mathan on 03-20-2009 01:32 AM
(5,186 Views)
Accepted by topic author Robin Hood
Hi Vipull,
     Find the attached vi to turn ON and OFF the LED in a simple way.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(5,185 Views)
Hi mathan, altenbach and baji,
                                                    Thank you very much for your help.
Regards
RobinHood
(5,147 Views)
Hai vipull,
Is your problem solved? If so please mark either my post or Baji's post (Whichever you think is the best solution for your query). This will help others facing same problem and looking for a solution.
Mathan
[BTW, are you using JoeLabVIEW signature with small change? Do you like that? Hmmmm let see whether he look into it and comment.]
(5,140 Views)
Regards
RobinHood
(5,111 Views)
Dear vipull,
Thanks for marking solution. Please do keep this practice hereafter. Thanks for your time.
Enjoy wiring.
Mathan
(5,108 Views)
