03-19-2009 11:01 AM
I want to save calculated data with the express Vi "write to measurement".
Therefor I sent the calculated data from formula node to an array and then to the express VI "write measurement data"
The result is al three measurement rows are in one column. And it saves only the last point.
What could I do?? Do you have any good ideas?
Thank you very much
03-19-2009 12:29 PM
Can you provide a screen shot of your code or maybe a sample vi?
03-20-2009 04:20 AM
yes of course
That it is:
03-20-2009 05:24 AM
Hi jonas,
I am not clearly understood your question. The result is al three measurement rows are in one column- so now you having 4 data points one aquired data and three calculated datas, u want put 4 datas in the same column? and repeat the iteration?
X_Value Untitled Comment
0.000000 0.000000
1.000000 0.000000
2.000000 0.000000
3.000000 0.000000
0.000000 1.000000
1.000000 0.000000
2.000000 0.000000
3.000000 0.000000
0.000000 2.000000
1.000000 0.000000
2.000000 0.000000
3.000000 0.000000
0.000000 3.000000
1.000000 0.000000
2.000000 0.000000
3.000000 0.000000
0.000000 4.000000
1.000000 0.000000
2.000000 0.000000
3.000000 0.000000
0.000000 5.000000
1.000000 0.000000
2.000000 0.000000
3.000000 0.000000
0.000000 6.000000
1.000000 0.000000
2.000000 0.000000
3.000000 0.000000
0.000000 7.000000
1.000000 0.000000
2.000000 0.000000
3.000000 0.000000
0.000000 8.000000
1.000000 0.000000
2.000000 0.000000
3.000000 0.000000
0.000000 9.000000
1.000000 0.000000
2.000000 0.000000
3.000000 0.000000
0.000000 10.000000
1.000000 0.000000
2.000000 0.000000
3.000000 0.000000
0.000000 11.000000
1.000000 0.000000
2.000000 0.000000
3.000000 0.000000
Like this?
03-20-2009 06:51 AM
I want to save the calculated datas as well as the datas from the measurement.
Example:
| X_Data [time in sec] |
pressure 1 | pressure 2 | pressure 3 |
| 1 | 0.1 | 0.1 | 239 |
| 2 | 0.2 | 0.1 | 400 |
| 3 | 0.3 | 0.1 | 561 |
| 4 | 0.4 | 0.1 | 722 |
| 5 | 0.5 | 0.1 | 883 |
| 6 | 0.6 | 0.1 | 1044 |
| 7 | 0.7 | 0.1 | 1205 |
| 8 | 0.8 | 0.1 | 1366 |
