hOW CAN i SAVE CALCULATED DATA WITH expressVI
I want to save calculated data with the express Vi "write to measurement".
Therefor I sent the calculated data from formula node to an array and then to the express VI "write measurement data"
The result is al three measurement rows are in one column. And it saves only the last point.
What could I do?? Do you have any good ideas?
Thank you very much
(2,760 Views)
Can you provide a screen shot of your code or maybe a sample vi?
(2,744 Views)
yes of course
That it is:
(2,727 Views)
Hi jonas,
     I am not clearly understood your question. The result is al three measurement rows are in one column- so now you having 4 data points one aquired data and three calculated datas, u want put 4 datas in the same column? and repeat the iteration?
X_Value    Untitled    Comment
0.000000    0.000000
1.000000    0.000000
2.000000    0.000000
3.000000    0.000000
0.000000    1.000000
1.000000    0.000000
2.000000    0.000000
3.000000    0.000000
0.000000    2.000000
1.000000    0.000000
2.000000    0.000000
3.000000    0.000000
0.000000    3.000000
1.000000    0.000000
2.000000    0.000000
3.000000    0.000000
0.000000    4.000000
1.000000    0.000000
2.000000    0.000000
3.000000    0.000000
0.000000    5.000000
1.000000    0.000000
2.000000    0.000000
3.000000    0.000000
0.000000    6.000000
1.000000    0.000000
2.000000    0.000000
3.000000    0.000000
0.000000    7.000000
1.000000    0.000000
2.000000    0.000000
3.000000    0.000000
0.000000    8.000000
1.000000    0.000000
2.000000    0.000000
3.000000    0.000000
0.000000    9.000000
1.000000    0.000000
2.000000    0.000000
3.000000    0.000000
0.000000    10.000000
1.000000    0.000000
2.000000    0.000000
3.000000    0.000000
0.000000    11.000000
1.000000    0.000000
2.000000    0.000000
3.000000    0.000000
Like this?
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(2,719 Views)
I want to save the calculated datas as well as the datas from the measurement.
Example:
X_Data
[time in sec]
pressure 1 pressure 2 pressure 3
1 0.1 0.1 239
2 0.2 0.1 400
3 0.3 0.1 561
4 0.4 0.1 722
5 0.5 0.1 883
6 0.6 0.1 1044
7 0.7 0.1 1205
8 0.8 0.1 1366
(2,707 Views)
