LIN protocol example
Can anybody explain me this misunderstand about LIN protocol (LIN 1.3)
My entry Frame is:
Sync break field :         0x00
Sync field out:              0x55
Identifier:                     0x50
Data 1:                         0x00
Data 2:                         0x32
Data 3:                         0x00
Data 4:                         0x00
Checksum:                  0x00
My request frame is:
Identifier:                     0x1F
My answer frame must be:
Identifier:                     0x50
Data 1:                         0x??
Data 2:                         0x??
Data 3:                         0x??
Data 4:                         0x??
Checksum:                  0x00
What is wrong with my program in LV, please find attached picture.
Message 1 of 12
(13,631 Views)
How i know LIN protocol in LabVIEW works with DB. and You must at start do initialization fo all IDs which You will use, first idea that can help You is this. check are You initialize both IDs or no?
Please in feature if it is possible shear code for have more detailed information.
With Best Regards
Certified LabVIEW Architect (CLA)
Message 2 of 12
(13,606 Views)
What is mean DB?
How can initialize both ID?
Please find attached LV code, along with code I'm using NI USB-8476.
Message 3 of 12
(13,588 Views)
DB Database
I use LIN interface with NI-XNET drivers, and how I am reading Your device documentation, there also uses NI-XNET.
Look at NI_XNET help and examples. NI-XNET use DB for transfer and receive data.
I finde this 2 links, which can help You in this situation, if I will find other information I will write You.
https://www.ni.com/en/shop/seamlessly-connect-to-third-party-devices-and-supervisory-system/introduc...
https://www.ni.com/en/shop/seamlessly-connect-to-third-party-devices-and-supervisory-system/ni-xnet-...
With Bets Regards
Message 4 of 12
(13,570 Views)
Also this link:
https://www.ni.com/docs/en-US/bundle/veristand/page/xnet-overview.html
With Best Regards
Message 5 of 12
(13,566 Views)
Try this, I write this for me, sorry can not give You source....
You must at first install NI-XNET drivers.
With Best Regards
Message 6 of 12
(13,553 Views)
When I run your sub VI from project is appears error below, I think that you can resolve it.
Message 7 of 12
(13,517 Views)
You must run in LV2013, I have that version, and build this with LV2013.
or after 1 days I can give You with LV2014 version.
With Bets Regards
Message 8 of 12
(13,491 Views)
Hrachya, I am afraid that this is not solution for my LIN communication problem, because I am using NI USB-8476 adapter.
Message 9 of 12
(13,473 Views)
Do You try this? or You think?
Because this is from worked project, and it works corect.
With Best Regards
Message 10 of 12
(13,463 Views)
