LLB Conversion
Hi, can someone please Convert this file to Labivew 20.0.1(64-bit)
Source file Labview 7.1
(1,143 Views)
Your VIs are actually in LabVIEW 6.0 and you can open them in LabVIEW 2020 directly, but they are broken because CINs are no longer supported.
This entire set looks like a driver for a non-NI device. Maybe there is a current version available somewhere. What is the device?
(1,085 Views)
It's a Measurment Computing DAQ USB device. Due to windows update need to convert to Labview 20
(1,036 Views)
Have you researched if newer drivers are available? (e.g. here)
(1,015 Views)
Yes
I think, I need to design using ULx
Thats the only solution.
Thank you for the help.
(977 Views)
HI
After installing ULxForLabview64, When I try to select a 64-bit DLL in a Call Library Function Node in 64-bit LabVIEW 20.0.1
I get a dialog stating:  "The library selected is not valid for the current platform. For example, you are running 64-bit LabVIEW and the library might be a 32-bit library"
Can u tell where the real issue is because both are 64 Bit.
(941 Views)
