LM500 error -1073807202 Old VISA Open in LM-500 Initialize.vi->LM-500 Operate.vi
Hi all,
I am new using labVIEW and I would really appreciate if you could help me with an error.
I am trying to control a Model LM-500 Liquid Cryogen Level Monitor (Discontinued).
Its drivers are available on-line and I have download them and I am trying to run the demo.
When I try to run it I have the following error:
error code -1073807202
The LM-500 is connected to my computer via serial RS232.
I don't know which could be the error. I would really appreciate if you could give me any idea about it.
These are the drivers:
http://www.cryomagnetics.com/drivers/LM500LV6_1.zip
Thank you so much for your help 🙂
(3,228 Views)
I think you may be missing visa runtime or something similar. Have a look at this link: http://digital.ni.com/public.nsf/allkb/1D1736BFD24A09878625742500241386
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,213 Views)
I have installed a NI-VISA 5.1.2 as I am using labview 2001sp1.
I have also replaced old VISA open by VISA open.
However I am still receiving errors in VISA open. Error 1073807346 ocurred at VISA Open.
Possible resons: VISA: (Hex 0xbfff000e) the given session or object reference is invalid.
Do you know which might be the problem?
(3,210 Views)
Accepted by Lauravsp
Thats because the new VISA open does not recognise the IO terminal class, you need to delete that and replace with the new type. Right click on the visa resource >> Create >> Control.
Select the rigtht COM port and try again
(3,207 Views)
Thank you! It has been very helpful!
(3,198 Views)
