I downloaded the EasyDLL.zip example from the "How to Build a DLL with Visual C++" tutorial website. I would like to simply modify this code to inferface some C++ code with LabVIEW. When attempting some simple modifications, the EasyDLL.cpp file compiles okay but when I try to build EasyDLL.exe I get the following error message:
Linking...
Creating library Debug/EasyDLL.lib and object Debug/EasyDLL.exp
LIBCD.lib(crt0.obj) : error LNK2001: unresolved external symbol _main
Debug/EasyDLL.exe : fatal error LNK1120: 1 unresolved externals
Error executing link.exe.
EasyDLL.exe - 2 error(s), 0 warning(s)
What is the simplest way to fix this problem? The EasyDLL.zip file can be found at: http://zone.ni.com/devzone/conceptd.nsf/webm
ain/3A1F4B7CBC68B636862567CC004D5CCA?opendocument
