LUTs resources FPGA
Good morning, I have a question about LUTs and DSP48s resources at my myRIO FPGA. So, I have a really not complicated piece of code, which I am trying to compile on my FPGA. Its how it looks like:
12121.png I have here some high thoughput math calculations, so I thought DSP48s resources will be used. But unfortunately, only LUTs are used, and even though there are only some blocks, my compilation status looks like this:
How is that possible? 470.2 percent? Maybe I have something wrong with my setting, or maybe something is broken.. I would appreciate aby kind of help.
Thank you 🙂
Message 1 of 11
(7,558 Views)
Could you please post your FPGA VI (no need for entire project) and we'll check it out.
Thanks!
Message 2 of 11
(7,537 Views)
Also it looks like you are performing a division with a known value since it's the sum of a control value (tau) and a constant (0.05).
Since division on FPGA is very expensive (and time consuming) it would be more efficient if you could calculate M = 1 / (tau + 0.05) on your host and perform a multiplication by M on your FPGA instead.
Message 3 of 11
(7,515 Views)
Ok I am attaching my VI (Buffer.vi) (in LabVIEW 2014, if earlier version is needed, let me know)
LocalDSP, I would prefer to have my calculations on the FPGA, as I am reducing the participation of the host to minimum. Its dynamic host interface (more fpga bitfiles), so that is why there is tau control at the beginning.
And beside that, isn't it still weird that two division calculations would take almost 500% percent of my LUTs resources? I am really confused 😕 Thanks you for feedback!
Message 4 of 11
(7,510 Views)
Ohh, and I also forgot to add, that I tried to do something simillar using DSP48e blocks, which were set to divide my fixed numbers. And in this case also my LUTs resorces were exceeded.
And here I dont use any Divide Highthroughput Math block. So there must be something I overlook and do not understand.
Message 5 of 11
(7,509 Views)
I noticed that you aren't using any BRAM at all, so I guess your FIFO is not a Target-to-Host DMA type.
What type of FIFO have you defined, how deep is it but more important what implementation have you selected. Since you are not using BRAM you can quickly run out of resources if you are using LUTs or Flip-Flops.
Message 6 of 11
(7,502 Views)
It actually is Target-to-Host DMA FIFO, so it may not be the reason 😞
Message 7 of 11
(7,499 Views)
I have to admit it's weird. I've compiled your VI with two different Target-Host DMA FIFO sizes, resp. 1023 and 65535 elements and it passed without problem and with obvious Block RAM increase for the larger FIFO.
Here are the two corresponding compile reports for my used Target (PXIe 7965R). I do not have MyRIO installed so cannot totally reproduce your situation. So somehow it itsn't using BRAM but rather slices on your target.
Target-Host DMA FIFO of 1023 elements
Target-Host DMA FIFO of 65535 elements
Message 8 of 11
(7,492 Views)
Accepted by topic author pers.jolanta@gmail.com
I forgot, the following is not ment to be a solution to your problem but can you try to reduce your FIFO size to 1023 and see how it compiles? This would prove/disprove the theory but also allow you to move on with your project.
Message 9 of 11
(7,490 Views)
Wow you were right! Now I manage to compile this code 🙂 I am soo grateful, I wish I turned to you testeday, I wouln't loose whole night for struggling! My present results:
For following piece of code:
But still question, why is my progam not using those DSP48s while dividing? Wouldn't be it more efficient?
Thanks ones again!
Jola
Message 10 of 11
(7,472 Views)
