LV'19 32 bit not downloading
Hi! I've been trying to download the LV'19 32 bit on my windows 10. But after successful download, it doesn't install the LV'19. It says "no operations performed". The issue with the 64 bit is that some of the toolkits don't work with the 64-bit version of LabVIEW (read in the document).
Message 1 of 9
(2,925 Views)
Are you installing through NI Package Manager?
Message 2 of 9
(2,902 Views)
I'm guessing (!!) that you downloaded the wrong thing.  Of course, you didn't provide the URL that you used, nor what you asked for, so it's only a guess.  You also didn't say anything about where you downloaded it.
I downloaded from the NI 2019 Download Site (I used Google to find the correct URL) and I now have LabVIEW 2019 (32-bit) running just fine on my PC.  I downloaded it to a Windows 10 (x64), which had no other version of LabVIEW installed, then installed LabVIEW 2019 (32-bit) using the "correct method" for installing LabVIEW 2019.  When I finished and rebooted, I was able to run LabVIEW 2019.
Not sure what you did, but something is wrong ...
Bob Schor
Message 3 of 9
(2,852 Views)
Yes, through NI package manager
Message 4 of 9
(2,809 Views)
https://www.ni.com/en-ca/support/downloads/software-products/download.labview.html#305508
Here's the link which is provided by the university.
I downloaded on the windows 10 (64 bit). I also have no other version of LV
Message 5 of 9
(2,805 Views)
This is what I got when I'm trying to install the LV32 bit. The screen is greyed out and I can't select anything.
But in the case of LV64 Bit I have the option to select but it says "Network error"
Message 6 of 9
(2,802 Views)
You do not need to download it manually if you are using the package manager. Just find what you want to install and press "install".
Message 7 of 9
(2,799 Views)
I just tried which you suggest but it still has the same issue.
I've attached the pics. Please see them
Message 8 of 9
(2,797 Views)
What does it show on your "Installed" tab?
Message 9 of 9
(2,786 Views)
