LV 2009 SP1 EXE Builder issue
Hi Guys:
            I found that the exe file built from LV 2009 SP1 can be easily extracted by WinRAR , i can see all the main or sub vi , is this a bug? or a settings risk? I haven't found the same problem in  LV 8.6 ,
thanks
(2,671 Views)
As I understand this is an unintended feature which was changed in LV 2010. I don't think this is a risk, because the VIs have no block diagrams. Some can exchange a VI but this will alter the checksum of the application file. In this case it is on the risk of the other one.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,657 Views)
Accepted by topic author adobefree@gmail.com
I do not think you should think to much about it. One of the first discussions about it  is here http://forums.ni.com/t5/LabVIEW/decompiling-2009-executable/td-p/991662. It is correct that they will be able to extract the VIs But they will not be able to see any more than you show in your program.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,646 Views)
