08-12-2010 03:11 AM
Hi Guys:
I found that the exe file built from LV 2009 SP1 can be easily extracted by WinRAR , i can see all the main or sub vi , is this a bug? or a settings risk? I haven't found the same problem in LV 8.6 ,
thanks
Solved! Go to Solution.
08-12-2010 06:03 AM
As I understand this is an unintended feature which was changed in LV 2010. I don't think this is a risk, because the VIs have no block diagrams. Some can exchange a VI but this will alter the checksum of the application file. In this case it is on the risk of the other one.
08-12-2010 06:58 AM
I do not think you should think to much about it. One of the first discussions about it is here http://forums.ni.com/t5/LabVIEW/decompiling-2009-executable/td-p/991662. It is correct that they will be able to extract the VIs But they will not be able to see any more than you show in your program.
