LV 2011 Build Installer Error code -30
Using LabVIEW 2011 SP1 winth Windows 7.  Made changes to a program and tried to create a new executable and installer.  Executable worked fine.  Got the following error when I tried to create an installer:
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> IB_MSI.lvclass:Build.vi >> IB_MSI.lvclass:Engine_InitializeDistribution.vi >> NI_MDF.lvlib:MDFConfig_SetDistributionLanguage.vi
Loading product deployment information
*** Error: Improper function call or command line argument. (Error code -30)
*** Error Details:
Error in MDF API function: _MDFConfig_SetDistributionLanguage
The MDF does not have support for distribution language LANGID 9.
*** End Error Report
Any help is appreciated.
(5,010 Views)
Accepted by SJT
This thread suggests uninstalling and re-installing LabVIEW, and making sure you have all updates.
http://forums.ni.com/t5/LabVIEW/Can-t-build-any-installer/td-p/2120890
(4,999 Views)
I have the same Issue with LabView 2016. In reinstalled LabView 32 bit and nothing chaged. Always this Error Message when I try to create an install package:
Click the link below to visit the Application Builder support page. Use the following information as a reference:
The following errors and warnings were recorded during the build:
Error:
Internal error.
Details:
The installer builder does not have support for installer language LANGID 9. Go to ni.com/info and enter the Info Code InstallerBuilderSupport to obtain more information about errors generated when building an installer.
Code:
-30
Where is this missing LANGID 9?
(4,511 Views)
Hi Tegich,
When you reinstalled LabVIEW, did you try explicitly right-clicking the setup.exe and running the installer as an administrator?
Also, I'd recommend posting this question on a new thread so that more people are likely to see it.
Brandon Grey
Certified LabVIEW Architect
(4,490 Views)
