LV 7.1 Tool Palette ???
The Tool Palette in LV 7.1 can be called temporarily with a Shift-Right Click but I am not able to keep the Tool Palette visible or "Pinned". It is not listed in Window menu. Hints?
(2,983 Views)
OK, so it shows up if the Window is extended. Rather a waste of time.
(2,983 Views)
Go to "tools...options" and uncheck "use abridged menus" (upper right on first options screen).
Now it will always be available directly under "windows..show tools palette".
(2,983 Views)
Thank you.
(2,983 Views)
